D16 engine
2.4K views 12 replies 5 participants last post by  clinchy
#1 ·
hi are b16 and d16 engine parts interchanerble? ie manifolds plugs, rocker covers filter, also can i put a b16 head on the d16 engine to convert it to a vtec?
#3 ·
ive been told not to bother...wanted more power from my d16. If your going to do an engine swap (read your other thread) then buy the engine you want and put that in rather then adapting a different engine. i hear the B18's are good but then all honda engines are good in some way :D
you can put a d16z(some number cant remember atm) head on the d16 you have to make it vtec. dont try and mash different engines together (unless you have a engeneering degree, then you can work out tollerences and shiz)
good luck
#5 ·
you can put a d16z(some number cant remember atm) head on the d16 you have to make it VTEC. dont try and mash different engines together (unless you have a engeneering degree, then you can work out tollerences and shiz)
good luck
i never said a D16 cant make good power, just a D16 non VTEC N/A wont make power.
i run a D16 making 282bhp at 7,900rpm.
you can put D16Z6 or D16Y7 heads onto a non VTEC block, but B and D parts are non interchangable.
#11 ·
What engine have you got atm? This info would help us in recommending the best way to go for more power. The D16Z6 is 135bhp IIRC? Sure someone will correct me if I am wrong.
