Just wondering what the signs of a gearbox going are, I have a civic 1.5 ls and it kinda sounds like reverse in st gear like a whining ?
Mine does it in 2nd gear mainly, a whine that increases with the engines speed, it does it in first and 3rd aswell but not to the same degreeVtec2011 said:I have the exact same problem. Mine makes a loud whiney noise in 1st gear, it gets louder when the engine is warmed up. I have been told it might be the thrust bearing which is nothing serious. I will be putting new gearbox oil in to see if that makes any difference..
I found this really helpful as i never really touched gearboxes. Thanks for the instructions and the photo :thumbup: This looks like an easy & simple task! I know i should go by the recommended oil grade but can thicker oil than usual stop the whiney noises? Because when i had my van i used thicker oil to stop the whiney noise from the axel lolRoylewaa said:They always stock it so you should'nt have any problems getting it, If your anything like me you will probably drool at the type R they always have in the showroom aswell![]()
Remember to take the car for a bit of a drive to warm the box oil up and it will drain alot quicker, Here's a pic borrowed from Civic 5, pretty self expanatory, bottom plug to drain and top to fill, fill nut is a 17mm bolt, As mentioned make a filler out of garden hose pipe and bring it up into the engine bay with a funnel attached to it and fill slowly, you can't overfill as it will just come out of the hole, really important to have the car on level ground
You've mentioned aswell it could be your thrust bearing, mine is a little noisy aswell so could have the same symptoms
