Hi guys,
Does anybody know how to remove the left hand front wing as I can't seem to find this information in the Haynes Manual. Its for a '98 Civic 3 door 1.4i.
Thanks! :) x ;)
Try opening the door, there might be a few bolts in the gap...if they're anything like CRX's you will scrape your knuckles so go slow :mrgreen:
Front left wing:
Open bonnet
Look on top of wing inside the engine bay, there will be 3 bolts, unscrew these and the top of the wing will be loose off of the chassis.
next ones are little plastic ones under the arch, holding the plastic arch on, take them off with care, try not to snap them.
Next ones are next to the door, open the door and you should be able to see them... then there is a couple at the very bottom of the wing, under the door, take your mud guard off, then pull back your sideskirt carefully, then undo the bolts behind there, that should be it im pretty sure... if it isnt, you might have to take headlight out and front bumper...
would that work with a civic 02
coz my n/s wing and light is damaged and the bumper
i need to take off all 3 :S
