Hi All
Looking for a little help. May sound easy but I cant get to grips with it. One of the sprays for the windscreen wash misses the windscreen, sprays over the car and gets the car behind. Although comical its little frustrating now. The small head for the spray is not dislodged or at the wrong angle and does not appear partially blocked. How easy is it to partially dismantle and clear the innner tubes? Any advice much appreciated.
Kind regards
Neil
you can angle them with a pin. they may look straight but are adjustable. push the pin inside a small amount and push. might be stiff 1st time u move them. easily get it straight!
or. yes they are very easy to dismantle, if you can see them. normally stuck to the bonnet and you can pull the hoses off easily.
what car do you have? my ek you can see the whole lot.
Thanks very much, I've got an 8th generation civivc (56 plate) so the spray head is in the grill between the windscreen and bonnet.
Will give the pin trick a go, thanks again.
Regards
