Hi,
I drive a 94 Honda civic 1.5 LSI auto and i velieve i have a fault with the crank shaft sensor, however i can't seem to find where it is on the engine, can someone please help me?
did you bridge the self diangostics plug and get code 8?
the sensor is actualy incorperated into the distributor and if it's broken the whole distributor needs replacing, i would recomend you check the sensor with a multimeter. honda distributor last time i checked was £360.
