Hi every 1 ive got a 96 p reg civic 2 door coupe 1.5 lsi but the 92-95 shape bought a turbo kit which is modified to fit that car/engine, would i need another ecu to run it properly or would i get away by remapping the standard 1? And would i need to change anything else? cause the person who i got it off said he did not change anything everything was standard but when i spoke to the mechanic that fit it he said it was fine but the engine management light was on? Thank you very much!
What Turbo kit is it and how much boost will it be running?
I believe if your not running much boost then the standard ECU will be able to cope with it, if you are planning to run a bit more you will need to look into getting it remapped.
your running an OBD-1 ECU which is re-mappable and is a must along with injectors and fuel pump. the engine check light is beacuse you MAP sensor is seeing pressure.
you could always run a missing link and FMU but i would not recomend it.
Hello & thanx every, what it is i don't what kind of turbo kit it is orboost to run it at or the psi as i have'nt got a clue the person who i bought it of din't know aswell lol never done or know anything about all that just thought a turbo kit already modified to fit my 1.5 lsi coupe straight bolt on to my engine its sounded wkd & bought it, its my 1st project as i always just wanted a faster civic & now my mates are saying ill need another ecu eg to a 1.5 vtech n some sayin remapp it but i don't know so id appreciate if some 1 that can give me bit more info please thank you!
i wouldnt fit it your self if you dnt no nothing about the kit. i also would get it set up (mapped) as you dnt want it rich or too lean. i would set it up to 6psi at first this will be a safe boost if you dnt no what turbo it is .
