Been offered a set cheap with the carryiers off a 96 Integra Type R.
Will need new discs and pads but as my brakes will need replacing soon anyway Im not to bothered.
First things first, will these go on???
iirc they will go on but you need to grind off a couple of bits and add spacers?
Also whats the min wheel size these will go under? 15's Im guessing?
Many thanks in advance.
Lee
Its an early integra so its a 4 stud mate same as mine, but are they not 1x114 centre bore? where as my EJ is 1x100?
So I could run MG ZR 282mm discs as the calipers are the same as a rover 600 ti.
Bolt pattern the same.
