1 - 17 of 17 Posts
Whilst staring lovingly at my car earlier i noticed that the front tyre is larger than the rear 1 although they are all 14" steelies
and on the opposite side the rear one is larger than the front one >:-(
Does this need to be sorted asap, need to find my jack!
Soz i know this is tyres/susp[ension but i cant be arsed to move it now!
Discussion Starter · #5 ·
Soz im still hungover gettin all confused with Boot, rear storage boot :S
Erm i dont know the car is outside and im sat in my boxers sippin a fosters O:)
But they are 100% visually different!
put the two larger tyres on the rear for now.
whats the size of all four eg 185 14 65???
dont work on it drunk tho no good will happen
Discussion Starter · #7 ·
Lol im not drunk just only drink i had in the house and highly dehydrated!
Will get a showa on and get a look in :)
read the sidewall to us and we will tell you!
steel wheels will probably have
185/60 R14 T
the numbers can be diff and the T might be H
Discussion Starter · #10 ·
[Front bumper]
[175/65/14/82t] [175/80/r14/88t]
[175/80/r14/88t] [175/65/14/82t]
[Back bumper]
Looks nioce n safe :-
ok are they directional tyres ? it will say on the side wall
really the front tyres must match or it will pull on side and think its cornering
put the '65' tyre of the rear on to the front
right put the 65s on the rear and the 80s on the front
then swap the 80s for 65s when you get your tyres changed in the future
btw the 80s are taller. the ones specified for your car are 65 height.
t rating is 113mph max. h is 118. v is 149mph.
to wear it out faster so when you get new ones that are the right size you've got the most wear out of them. you could put them on the back. as long as you have the same size on the same axle you will be okay.
http://www.miata.net/garage/tirecalc.html" onclick="window.open(this.href);return false;
use this to calculate the difference
Discussion Starter · #16 ·
Lol well they are all brand new tires and ill b gettin some new rims soon as only on sttelies at the mo so whacked the 65's on the front and 80's on the back :)
1 - 17 of 17 Posts
