hi ive got a 2005 sport and just recently ive been getting noise when the engine is running.It stops when i press the clutch in and when you get to a normal driving speed(around 30mph)and sounds worst when in low gears.I think its coming from the drive shaft or maybe the gear box but im not sure.Just wondering if anyone has had the same problem or any idea what it might be? cheers
hi, my ej9. im a mechanic have the same problem. its the gearbox as when the clutch is pressed the gears in the box stop turning. if you like u can get the gearbox rebuilt and new bearings fitted but u would be cheaper getting a second hand box.
simon
