How do I remove the ariel base?
Do I need to take all the roof lining and pillars out?
Thnx
bump
Well some d**k pulled my ariel off and the screw snapped in the base so I need to replace the base and honda quoted me loads to replace it so was gona do it myself
Ok i just done this my self in my type r
The way you do it is unscrew 2 screws each side from the plastic pit where the seat belts go. 1 of the screws is located level with the seat belt and the other is the opisite side and you have to take the plastic cover off
then you need to lift it up and as you do pull the grey bit above it so the whole lot removes
carefull not to snap any clips. slide the whole thing away down the seat belt
next pull down the roof lining. should be 2 clips either side and you should be able to pull down far enough underneath
then disconnect the 2 aerial wires ( just pull down and they both come away )
then twist the brase bolt with your hand and unscew all the way then you can remove the base
sorry if it sounds complicated. its easyier then you think
