Hi guys,
I have just had to replace the car battery and alternator on my 2004 1.7cdti civic. However now the remote central locking is not working. I have tried re-programming the key fob using the following instructions:
1 Insert the key in the ignition and turn it in the on position.
2 Within 4 sec push the lock button on the keyless remote.
3 Turn ignition off and put it back on.
4 Within 4 sec push the lock button on the keyless remote.
5 Turn ignition off and put it back on.
6 Within 4 sec push the lock button on the keyless remote.
7 Turn ignition off and put it back on.
8 Within 4 sec push the lock button on the keyless remote.
9 As soon as you will hear the car lock.
10 Push the lock and you should hear the car lock.
11 Push unlock you should hear the car unlock.
12 With in 10 seconds turn off the ignition and take the key out.
13 Now you can test how you programmed the Honda keyless entry remote.
Everything works ok until I get to step 10. I can hear the central locking, however the doors do not lock. However the unlock button works fine at this stage.
Then when I take the key out the ignition, the key fob doesn't work at all.
Any ideas on why this is happening and why I can't re-program my key fob???
