hi guys, got a eg civic with this style spoiler...
the rear washer pipe has popped off the nozzle cos of the ice, and the nozzle has a tiny access hole at the back of the rear wing, however pushing the hose up just makes it go inside the wing and fill the whole thing up with water!!! under the wing there seem to be 3 black plastic sections (2 small edge ones and 1 big central one) are these removable to allow access to the nozzle? im assuming they are because im guessing the bolts that hole the whole wing on are under there too, but i dont want to force them but theres no way im going to get the hose back on just by pushing it around through that tiny hole!!!!
many thanks, mike.
They will be held on by trim clips, you can buy a trim clip remover tool, or sometimes you can wrap a screwdriver in electricians tape (to protect body) and try prizing it off. you can buy replacement clips if they break (they are very easy to break).
