ok folks a quick question iv got a 1999 civic coupe em1 with a cat back system on it and ive just bought a de cat pipe what gains will that give me and will it make the exhaust louder?
thanks for any input
An exhaust on it's own doesn't do much at all.
A de-cat is not worth the hastle of having to swap it out come MOT time either. You're just destroying the planet for 1hp. Maybe. A high flow cat will still give you a gain (it's clean for starters) and keep things clean and you'll pass your MOT without messing about with a de-cat also.
If you have a proper intake, a good header and a good exhaust you might see up to 8whp if you're lucky, you'll need to spend some cash to get 'real' gains however.
Of course the above advice will see gains tenfold with extended performance upgrades such as cams, stroker kits, high compression pistons, nitrous ;)
