Hi first time here.
I own a 2005 ep3.
Opened engine oil cap while doing a top up and it snapped in two. Managed to get the thread part out, a rather clean snap. Only bit that was missing was a plastic shard once I pieced it back together. Didn't see it drop in and its nowhere to be seen on/in the bay area.
The shard is about 4x1x0.5 mm in size. If it had fallen down inside where should I go from here? Should I even worry about a piece so small, or will it get whipped up into something delicate?
Iv not started it up and a replacement cap is on the way.
I have had a good look inside the filler hole but no luck, not taken the rocker cover off yet either, should I?
