1 - 20 of 20 Posts
have u checked the obvious, fuses??
you mite just have over stressed the motor and it cut out to cool down, take you door card off and give all the workings and sliders a good coat of WD40, i did this when my door lock refused to open, now you can blow on it and it slides smoothly!!
If it was slow for a while, sounds like it just packed in. Door motors are infamous for this.
Gotta take your door apart and fit a new motor. The new motor will be way fast though! It's a quite a bit of work, and can be expensive if you buy the new motor straight from Honda which you may have to do.
Discussion Starter · #4 ·
yeh ill have a go at that when it stops raining for more than 30 seconds lol.. i dont really wana pul all the white plastic off the inside of the door though.. seems like it would stop moisture gettin in...
could be, if its been sticking then it just suddenly gives up, could be a power surge, come on it'll take you 2mins to find and check, if not get the door card off and put two live wires over the motor terminals, if it still goes then all is good, if not your motors fried and you'll need a new one, but they look like a bitch to fit!
Skinny said:
nah its like glued to the door.. dont suppose its really needed, its just that it must be there for a reason. i'll just rip it off.. lol 8-|
i see i am going to have to keep an eye on your antics the door membrane as its called stops the water coming in your car and soaking the door card and carpets always put it back get some gaffer tape to repair it if you wreck it :)
1 - 20 of 20 Posts
