i have a "Auto Gauge Performance Merers No.1" Oil Pressure gauge which i really want to put in because when i reach vtec the oil psi should go up and look quite "Cool" lool...
So i have 3 questions: First one being... The Oil Pressure did NOT come with them T Spliters and obviously i want the oil light on the cluster to work soo where can i purchase 1 of these ?????? i think there called "Remote Oil Pressure Tee Kit" i would rather buy it from a store than online soo i can see the size of the thread
number 2: the oil pressure sender has two sizes 1/8" NPT and a 1/4" NPT adaptor, will these fit my car (B16) or would i need a different size ???
number 3: im not confident to install this usually i would be but when i asked a friend he said i would need to be able to get under the car to fit it on... so how much do you recon someone could fit it on for ?
thanks in advance
Done my research its a 1/8" fitting.... but iv also heard that sometimes these oil pressure senders on the T splitter with the old oil pressure canactually make it fall off as your driving thus making you loose all your oil and damaging your engine and to use a "strain relief" to avoid this situation... True or False ?
hi
i would have thought a good quality t piece would have been fine ,the only problem i could see you will have is the sender unit for the gauge is quite a lump too be hanging on the t piece if its a worry,
you could always mount it on a remote oil pipe off the t piece and mount the sender on its own but thats more work .
something like this is what i had in mind if your worried.[attachment=0:2wgg994n]8c4e_1.JPG[/attachment:2wgg994n]
yee thats what i want where did you get it from ????
the oil pressure unit is quite big and heavy so ye im a little worried that it will fall off at like 70 mph
