Morning all
  1. After abit off help with a project and hoping someone has the answer, I'm using a b16a in a classic mini, but the problem I having is that as Im running a GPS Speedo I don't have a signal from the vss to the ECU, I have the signal wire from the sensor but read this would normally be converted to a pulse through the cluster then To the ecu... So my question is there a way to convert the signal from the vss to a pulse that I can wire to the ECU
Cheers
