Hi, Im new to the forum but hope one of you can help....
My Civic 1.8 VTi failed its MOT due to a number of things (most now sorted) but the main one is emissions.
Results were :
1st Fast Idle test
CO 4.15%
HC 171ppm
Lambda 0.89
2nd Fast Idle test
CO 8.40%
HC 351ppm
Lambda 0.78
passed natural idle test.
Ive replaced the air filter, the spark plugs are clean, its had additive in the fuel, mechanic checked valve clearance and Honda couldn't confirm the fault through their diagnostic what the issue is.
Any ideas?? Its a 98, R plate.
Im going down the replacement ECU/remap existing ECU route but a replacement is £100 ++++ and finding a garage that can remap my car is a nightmare.
Thanks in advance.
Tris
Results were :
1st Fast Idle test
CO 4.15%
HC 171ppm
Lambda 0.89
2nd Fast Idle test
CO 8.40%
HC 351ppm
Lambda 0.78
Thanks in advance.
Tris
