So my mk9 1.6d has thrown a 'PGM-FI' fault. From what I can find out it's related to Fuel injection system!
So plugged my ELM327 bluetooth box in and tried a few apps to see if I can read the codes but it says no fault codes logged!!!
Just tried a few other apps like:
Torque (lite)
Clear and Go
ODB Arny
MotorData
None showing any codes!
So is it that I need a better reader than my ELM327?
Reading other threads sounds like it could be the MAP sensor! On the 1.6d any ideas where it is as it's only about £20 so might be worth just fitting. Mind you if I can't reset the fault codes then I am no further on really.
So any ideas or just bite the bullet and take it to Honda?
Cheers
Hi there, I know it is a while ago now but did you ever find out the issue?
I have the same problem.
Stevie
