I have a 2007 Type S Civic. I appear to have water leaking into my passenger footwell. It doesn't smell like coolant. As a result, it's freezing/misting heavily on the inside windows.
The other day I cleared out the track below the windscreen wipers and this seemed to help but there is still a slight wet patch that I can only assume is still leaking.
Today, I replaced the pollen filter. There seemed to be quite a bit of debris in there - so uncertain if this has been causing it?
I'm just wondering if anyone has any ideas? Are there any other nooks and crannies that I need to be clearing out tree debris from? Or is there anything else I should be doing?
Had a mechanic yesterday try to tell me that my car doesn't have an air con drain under the car and that air shouldn't be put anywhere near it! Not sure what anyone's views are on this - and if this needs doing as well?
Any advice much appreciated. Thanks.
