Hi please help i installed a hid kit in my eg6 civic and all of a sudden the lights turned off. So i checked the fuse and replaced it and now the hid dont work and the car dont start so i think its the immobiliser problem please can someone help? cheers
sounds like you have popped some fuses
hid require a hi start up voltage to fire the arc in the bulb but once there lit there require only 35w to run compared to a regular halogen at a minimum of 55w
also not being rude but if you used a cheap hid kit they do have issue with electronics on cars in some cases
better hid of today have digital ballsts which dont give as much problem
but you should always relay hids because of the igniter surge on start up .
