Hi all
My Civic keyfob is faulty. I've replaced the batteries, but it will only lock remotely, not unlock. The little lights on the fob flash when I press either button, but as I said, it won't unlock. Can anyone shed any light on this?
I can imagine there could be many different reasons for this. Unless someone else here has come across the same problem I doubt you'll get it resolved unless you visit a Honda retailer.
Discussion Starter · #4 ·
You're probably right. It's probably something wrong in the actual car. Weird.
It's the type one kind, with 2 buttons. They both make the little lights flash when you press them.
take it back apart and check the mechanical operation of the button. if you've ever taken something with buttons apart you might want to check that they perform the connection/switching part of the switch.
