interior light works sometime and not other but the light around the ignition hole works more ofter but is also a bit dodgy does any 1 no Wat it could b thanks
Ive looked at all the switches but cant find anything loose is this not a common problem then
Mite not be the switches mate, on the inside there will be like a little block thatl have the light inside it. Check that. I dont know your car, but on the EP's there is the switch or button on the outside, then from the back it sticks out and you can take it off, from there you can dismantle it etc.
