I am just about to buy a b18c jdm spec full engine conversion kit for my eg4 .I am wanting the 98spec as it has a few more horses but how can i tell if im getting a 98 spec or 96 because the place im buying from say they cant prove its from a 98 and they have only got a exhaust manifold from a 96 spec to sell with it.Which is the only wayi can tell as ive bin told the 98 spec comes with a four branch manifold and the 96 spec doesnt.Should there be a date stamp or will the be any engine numbers that will prove what year it is.Thanks
look out for engine codes, myself i aint sure which is which
but im sure teggy R's came with b18c, b18c5 and b18c6. dunno which are from what year or which are JDM spec.
Nuno
hey mate, from what ive just found out, there is only 1 JDM spec integra type r engine, and that is the B18c.
B18C (Type R)
VTEC
Found in:
JDM Honda Integra Type R
Power: 200 hp (150 kW) @ 8000 rpm
Rev-limit: 8,920 rpm
VTEC [email protected],800 rpm
134 ft·lbf (182 N·m) @ 7300 rpm
Transmission Type: 5-speed standard with LSD
Displacement: 1,797 cc (109.7 cu in)
Compression:y 11.1:1
Bore: 81 mm (3.189 in)
Stroke: 87.2 mm (3.433 in)
Rod Length: 137.9 mm (5.429 in)
Rod/Stroke Ratio: 1.58
Transmission: J4D (96specR w/ LSD)N3E (98specR w/LSD)
As for the UK spec teggys: same power, same comp ratio, same stroke, same displacement, same bore, less torque.
B18C6
VTEC
Found in:
1998-2001 Honda Integra UK and Euro Spec Type R
Type: 1.8 litre 16v DOHC 4 cylinder in-line
Compression: 11.1:1
Air intake diameter: 62 mm (2.4 in)
Power: 190 PS/139 kW/200 hp (SAE net hp) (139 kW) @ 7900 rpm & 131 ft·lbf/178 N·m @ 7300 rpm
Red-line: 9000 rpm
Transmission: S80 w/LSD
Hope this helps.
yes mate im sure this will help.Was also wondering when i change the integra b18c into my eg will i need differnet mounts and fuel pump.thanks
haha was gona mention the fuel pump!
yes mate, u will need a walbro 255 high presure, cost bout £80-£90.
and the B18c mounts will do, but will need modifying.
also make sure u get it mapped as soon as, cause the pump can dilliver ur whole tanks worth of fuel in half hour! making ur car run stupidilly lean, u dont wana do that.
Nuno
