1 - 10 of 10 Posts
I know it sounds silly,
i know where the strutbar mounting points are but is it fine to just go ahead and just crank the bolts loose as are'nt they somthing to do with the suspension, as i tried it earlier and they were rock solid and don't want anything flying off!
Cheers Gurus!
I just installed my one the other day its really simple.. just make sure you have the right size spanner mine wasnt that hard to take off i used a little (i mean a tiny amount) of WD40 let it stood for like 10 mines and the bolts came off with ease.. after you install it you will feel a difference i did steering felt a little stiffer and at higher speeds the car didnt seem to shake as much... after you drive it for the first time when you stop driving pop open the bonet make sure all the bolts are still tight..
Discussion Starter · #5 ·
Yeh just whacked it on but 1 bolt is completely seized, no amount of wd40 will solve it! but it sits tightly never the less and looks great 8-|
1 - 10 of 10 Posts
