hi ive just had a turbo fitted to my d15 1.5 coupe will dsm 440cc injectors fit on my car. thanks chris..
You need to check whether they are High or Low Ohms, if they are low you will need a resistor box, high Ohms injectors are usually more expensive, plugs should fit as you have the OBD1 system.
