Hi just picked up a new rear offside light to replace one that was broken. Can someone tell me how to remove the old one please? I noticed there are 3 bolts on the back of the new one but there is also a threaded hole underneath so wondering if the bumper has to come off too?? :eek:
Hi thanks that. I managed to remove it just about but still had trouble releasing the plastic lugs on the base of the light. I managed to get to the screw underneath with a long reach screwdriver because it was visible from under the car. When fitting the new light I just cut off the plastic lugs underneath to make to easier to install. The 2 bolts were more then enough to keep it in place tight. :)
