1 - 20 of 28 Posts
try tdi in manchester, ask for paul (mainly ep civics)
or cpl down south, there in the reccomended shops (all hondas)
both are good but quite expensive, as far as i remember dan pid £750 for his, inc ecu and set up (don't quote me on tht tho)
Discussion Starter · #7 ·
i think my keys have a chip in them that gets checked by sensors when the keys put in the ignition and the remote locking is infrared so was charged 30 to get one i got off ebay coded.
ebay-hondata unit for b16a2 96-00 civic vti..... like a needle in a haystack.....
mapping aint too bad tried a bit myself. wiv a honda cbr!!if you can get a cheap rolling road then thats one step. you can get a basic map for the car with the ecu normally but then you can tweak it yourself/professional to work even better to your spec. you may aswell get manifold and breathing sorted first.
oops bit of an old post :D:D
you could re map it but as with most hondas they are pretty well setup already. if you are putting on breathing mods and exh, getting a new cam and port polishing then maybe get it remapped. im sure you can't remap a standard ecu but if you buy a new one like this thread suggests thats ALOT of money. you can buy chips which you insert into teh loom and that changes the map slightly which can give you alot more response and power. they aren't cheap either
1 - 20 of 28 Posts
