come on then how hard is it to remove the cd from am ep3 we have all the bits to fit new head unit but have to remove
the cd housing from the dash
is this a dash out job or can you through the glove box and from under the steering wheel side????????????????
also how had is it to remove door cards for speaker upgrade
also silly question have they got rear speakers in the ep3's (i just work on it not drive it) lol
any good recommendation on direct replacment speakers
cant afford all the cd's need to get her ipod in there LOL
cheers
scrog
to get the stereo out you need to put the car in 3rd, and pull out the bottom half of the gear stick surround, then open the glove box to release the clips to undo the top half of the gear surround, then push it out. Then you will see 2 bolts holding the bottom of the stereo cage to the centre console. You access one from behind the glove box (the left bolt) and the other on the right hand side of the inside of the centre console. You will need a spanner to access these. Then you just pull out the whole centre section, then undo some more bolts to remove the stereo.
using the method i described, it`s not a hard job, just takes a while.
http://www.k-series.com/tech_document.php?id=10" onclick="window.open(this.href);return false;
there are rear speakers yes but i`ve never removed them myself
