Hi All,
Anyone know what might cause a hot starting problem (starts after its cooled down)....
then after a week a cold starting problem (starts after fiddling with the vacuum hoses and leccy bits)...
then after another week it does not start at all?
Car is a Civic 1.5 VTEC-E 1997, but I think this problem is a general problem.
Tia,
Bav
Discussion Starter #2
Update -
Gave the car in to a garage and turns out that the problem was...
a burnt out ECM/ECU unit which wasn't...
sending the correct signal to the fuel pump, so....
no fuel to engine!
Luckily the unit was repairable rather than having to buy a brand new one !
Possible causes like the battery is weak or the connections at the starter are corroded. Or it might be that the cables inside prevents the current from reaching the starter.
_________________
Petty Deh,,,, Hamilton, USA
Auto Blogger
Cargo Liner Blog
