1 - 16 of 16 Posts
hi all i have just bought a civic 1.5 vei and i want 2 put a performance manifold on but the cat is on the manifold. r all civic.s like this or can i use a cat from a different civic and put a performance manifold on and put a cat under the car please help many thanks shaun. i live in plymouth i have put piper cross panal filter iridum plugs on the car for now. i don't think i will do any more as i think it will be cheaper to start with an esi many thanks shaun
cheers mate wats a stubby and can i remove cat or do all civic.s of this year 95 have the cat on the manifold . can i put a full manifold on and move cat many thanks shaun
thanks thats a great help where can i purchase said manifold.s. if i put a full manifold on can put a cat under the car or is best to old manifold back on for mot also do u know wat performance exhaust work.s best on this car many thanks shaun
ebay would be a good start. you`d need to have the cat on for an MOT so it depends whether you want the hassle of changeover every year
The stubby won`t give much BHP, just a throatier noise. Full decat would be needed for an increase in power, plus you`d need an o2 sim to fool the engine into thinking the cat is still there. The o2 sim goes between the 02 sensor and the exhaust manifold
thanks is the o2sim easy fit and is the vei the only civic with a cat on the manifold as i have seen decat pipes for civic.s. is the vei hard to tune if so do u know which 91 to 95 civic is best for tuning besides the obvious vti many thanks shaun
besides the vti the other 92-95 civic to go for is an esi (1.6sohc vtec) engine code d16z6. there mods on these little puppies are endless!
Discussion Starter #12
cheers mate i will start looking an esi as i think it will be the cheaper route and do u know if esi have the cat on the manifold or is only the vei many thanks shaun
Discussion Starter #14
thats great an esi it is then. does the esi come in 2 door coupe or 4 door saloon as well as 2 door hatch many thanks shaun
1 - 16 of 16 Posts
