Hi guys
I’ve just purchased a type r ep3 a few weeks ago.
the car is on 78k with full service history
I’ve been noticing a noise on a cold start up for a split second when the car has been sitting awhile. (Doesn’t happen every cold start up , maybe 1 in 6/7).
I’ve replaced the starter motor. Noise is still there however it’s no where near as bad as it was.
Any suggestions?
Vtec Solenoid?
hopefully not the timing chain? (No history to say this has been done)
Thank you in advance
Nathan
I know this is a strange thing but have you checked the heat sheild over the top of the rear silencer. When they corode around the securing screws they drop down and touch the silencer. If so just remove the screws and fit larger plate washers over the holes or cable tie the sheild securely away from the silencer
