Hi All, I have a 97 coupe 1.6sr and when it heats up it misfire's and hesitates underload and low rev's but its fine when revving above 3000rpm and good when cold anyone got any idea's? Cheers
could be dizzy. i tried 2 second hand dizzies before found one that worked so it got mighty confusing tracking down the real problem. try changing the cheaper parts first (plugs, ignition leads) and hope that sorts it. good luck
i had a simular thing and my problem was i had water in the diz. took it off wiped everything and it ran fine after that
