hey, i think my heater blower is knackered in my car...unless hondas have rubbish ones (like the rubbish window regulators). When i put the heating on full...it comes out a little on the drivers side and on the windsheild..but no where else...passenger side and central console has next to nothing coming out. Even if i choose the specific ones still hardly anything comes out. would this be the blower?
i had the same problem bro...
you need to replace your cabin filter, or remove it until you have a replacment but if you remove id stretch a pair of tights over it only temporary just to stop any crap getting in...
assuming its the same design as mines...
remove the glove box (2 screws unber glove box)
remove metal plate (2 screws at each end then it just wiggles out)
remove the screw at the top its attached to the filter box and cant really be missed...
and remove screw at the bottom of filter box. <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< not 100% its at the bottom
the filter box should now just fall out but may need a little wiggle again
now you remove all the little metal clips holding box together and the plastic strap that holds the rest of it together and at will open up to reveal the filter.
i hope this helps you i know its not a great guide its just from memory :p
