1 - 11 of 11 Posts
I am pretty sure all B series 'boxs will fit all B series motors and the same with D and H motors. Someone correct me if i am wrong?
the b18 gearbox has longer ratios than the b16
theres an eco-vtec engine that has a very long 5th gear (does a higher top speed in 4th than 5th as the engine hasnt got much power)
twatnav said:
as far as i can tell from this useless manual .there is one gearbox for all 5th gen engines
no thats wrong! if your gearbox is fucked id just replace it with the same one, you'll fuck up the ratio swapping around!
or it may hinder your accel! you have to remember it aint just the gearbox that you need to fit, the driveshaft, sensor location etc may all be different from your car, id only recommend looking at other boxes when you know what your doing with them.
1 - 11 of 11 Posts
