Hi, i have now sourced a h22 lump on the cheap so thats stage one of the ek conversion.
Now i was wondering bout drive shafts and things??
Would i need to get custom ones or would the original ek4 shafts fit?
Sorry if that sounds like a dumb question but if i dont no then i need to ask lol :p
And can n e one tell me anythin else that would need to Changed for the engine to go in?
I would say custom ones but then again I don't know about the H22 conversion.
Just search for 'H22 engine converison' on Google.com or something, theres bounds to be tonnes of info floating around on it.
Right on! Any ideas one weres the best place to get these from? and a roughf price that ill be looking at?
engine mounts, good mechanic, driveshafts (donno how about the loom, what the obd is ), gearbox
...but if you can get it done, and your h22 is in condition then <3
You will also need the ECU from the car the motor came from.
Got a donner car, woo hoo!!
Does anyone no were i can get custom drive shafts and mounts from in this country??
Found loads of place that sell them in america but none ova hear!jammy05
1st Gear Member
Hansport make conversion kits for these, as for drive shafts I'm sure if you work out exactly what you need an engineering place should be able to knock you some up.
