If anyone's thinking of doing an engine conversion then let me know, i've done three this year, two being honda's and have done a turbo conversion as well so if you have any questions feel free to ask away
things to considder
1. will the new engine fit the old mounts, if not this can be time consuming and if you don't have the right equiptment it could prove difficult
2. if you have the room to work on both the cars at the same time this will make the re-build proce much quicker and easier
3. if the wiring looms are similar try to add the necessary wires rather then swapping the entire looms, this can prove eventful to say the least
4. often buying the entire car you want to source the engine from is the best way as this will mean you will have everything you need, some conversions often forget small parts that make the installation much easier/quicker
anything other then that is straight forward; unbolt it here, bolt it on there lol
things to considder
