1 - 20 of 152 Posts
For all the people who want to Engine swap the civics
Enjoy
Tools: 1/2 inch socket set, Breaker Bar, Torque Wrench, Spanner set up to 24mm, WD40, Copper Grease, Blowtorch (for anything stubborn) OH and of course a big hammer :thumbup: you'll also need an Engine Crane a friend or 2 and a pallet and straps to secure the engine on the floor.
Now to start:
Chassis:
(1992–1995) -
EG3 1.3 (D13B2)
EG5 1.5/1.6 SOHC(D15B)(D15Z1)(D15Z4)(D15Z6),(D16Y8)(D16Z6)(D16Z6)(D16Z6)(D16Y7)(D16Y5),
EG6 1.6 DOHC (B16A2), EH?, EJ1/EJ2
(1996–2000) -
EK9 1.6 (B16B) TYPE R
EK4 1.6 (B16A2) DOHC
EJ6
EK3 1.5 SOHC(D15B)(D15Z1)(D15Z4)(D15Z6)
EJ8?
EJ9 1.4 (D14A3)(D14A4),
EM1 (1.6 B16A2 vtec dohc )
(1995-2001) -
MB 1.4 (D14A2/A5/A7), 1.5(D15Z8/Z3), 1.6 (D16Y2/Y3,D16W2/W3,D16B2 etc.), (B18C4 1.8 L DOHC VTEC)
Next is the Common Engine swaps in that specific Chassis.
(1992–1995) -
EG3 1.3 (D13B2)
EG5 1.5/1.6 SOCH(D15B)(D15Z1)(D15Z4)(D15Z6),(D16Y8)(D16Z6)(D16Z6)(D16Z6)(D16Y7)(D16Y5),
For the EG chassis the EG3 (1.3) and the EG5 (1.5/1.6Sohc) the engine commonly swaped for the SOHC is the B16A2 DOHC VTEC out of the EG6 its a straight swap just need the engine mounts and ECU, Harness ETC, driveShafts, And bigger brakes. ;), However people also put the B18C4/B18C engine into the EG chassis from the MB chassis or Integra Type R's agian you need all the ancillary's ECU, Harness, Loom ETC, Driveshafts, you will need to buy aftermarket engine mounts (i think, Correct me if i am wrong), Also the K20A2 (EP3Civic Type R 2001-2006), K24A2 (CL9 Accord Type S, RB1 Oddyssey), H22A (BB1/BB4/BB6/BB8 preludes) are good engines to put in the EG chassis, BUT they do require severe modifications to get them to fit, e.g(200quid engine mounts), various parts relocated and obviously youll need all the previous parts mention'd before. Shafts/ECU/Loom. Blah Blah
Now for the EK Chassis common swaps will be from EK3 1.5 SOHC(D15B)(D15Z1)(D15Z4)(D15Z6), EJ9 1.4 SOHC (D14A3)(D14A4), Again the B16A2/B16B will be used from the EK4 (B16A2) and Ek9 (B16B), As previous its a straigh swap if you have the mounts/ecu/loom etc etc, the B18c/b18c4 is also a popular engine for both the EK not as simple as the B16a2 swaps, minor modifications are needed, uprated mounts for one. Engines that require relocation and extra bits and bobs are K20A2 (EP3Civic Type R 2001-2006), K24A2 (CL9 Accord Type S, RB1 Oddyssey), H22A (BB1/BB4/BB6/BB8 preludes) engines Also the 3.0/3.2l V6 J series engines from the Honda Legends/NSX will fit, but that includes removing the bonnet..... For good. :cool:
Hopefully this stops people asking what fits in what..... all the info is there i think, if i am missing bits please tell me and ill correct/add bits. :thumbup:
Best Regards
Adrian
yea copper grease, for the new bolts to nicly slide back in, makes life much much easier.
Thanks for this Adrian, now I know I can go ahead with a K24A2 swap :D Just one thing, what severe modifications are we talking about here?
Also meant to ask about the gearbox, do you need to pair the engine up with a gearbox of the same engine code? And will the gear linkage fit in an eg civic?
Discussion Starter #12
K seriers Boxes fit K series engines..... And sever mods will include re routing parts etc etc... remember the K seriers engines have the intake on the front and the exhaust at the back of the engine. and to fit the k series engines compared to the standard engines in most civic's youll have to fit the K24 the opposite way round. E.G the camgear side willl be on the drivers side. Unlike Say my Ek3 where the cam gear is on the passenger side and the gear box is on the drivers side. :thumbup:
Hope this helps.
hi ther sounds like u no what your talking about i looked thru what u have said about what will fit ok ill get to the point i have a crx engine d16a9 1.6 16v 1984 i dint cut one Wire when taken out i would like to put that in my ej9 as i have it just sat in my shed but would it be wherth putting that one in or just slap a 1.6 vtec in. :thumbup:
quetion guys i was wanting or well thinking about putting a y8 in my daily driver. I know the mounts shafts and stuff should be ok but how about imobiliser and keys and so forth?
Many thanks in advance
steven
Discussion Starter #15
use a P28 Ecu, dosnt have an immobiliser in it, Use your old Keys, will work the same way. :thumbup: Or you can take the immobiliser chip out of your old ECU. ;)
ah soz my fault yeah forgot to say its an EJ9 hatch 1.4 d14a4 at the moment in comet blue if wdx informs me correctly lol.
yeah seen the thread on swapping immob chips but does this really work?
only reason i ask is i went through a bad time in my life where i bought a 106 diesel and put a vtr conversion in it lol phase 2 engine clocks and all the **cker wouldnt start lol
stevie
I recently picked up a 1990 civic DX and I'm looking to swap motor for a little more power. My problem is I'm new to Hondas and don't know anything about them. What motors will fit, will I have to change motor mounts, would appreciate any help I could get. Thanks.
Discussion Starter #20
First.... What power you looking for?, How old are you?, whats your price? :thumbup:
1 - 20 of 152 Posts
