Hi all, right i have a 97 civic coupe 1.6 sr and i want more power, is there a bigger engine that'll go straight in
or any other idea's? i'm on a very tight budget!!!
Cheers
Yes there is B16A2 from civic 96 to 2000 it will fit straight in. If you buy the same engine but from 92-95 civic you have to switch your car from OBD2 to OBD1
Class info, im doing the same with mine but unsure whether to go for the b18 or b16 ? Is there much cost difference between the two. Apologies for jackin the thread but itll save making a new one. Thanks...
Well it depends which b18 you are going for. If it is B18C4 there is no big difference but if you go for b18C6 or better B18C JDM it will cost like 3-4 times more than a b16a2.
