Hi
My n/s front door and o/s rear door are locked shut and wont open inside or out on my 2006 civic i-vtec sport.
There is no resistance in the inside lock switches they just wiggle about freely.
This started off as an intermittent problem which leads me to think that the locks themselves aren't the issue.
Any ideas?
Have already had this problem once which led me to having a Honda technician break the lock and replace it (£150 as a foreigner) so anything I can do to avoid paying hideous repair prices I will consider.
Did you sort the lock out, I have the same trouble, how do they open door with it locked.
59 plate civic same problem rear passenger door not opening from outside or inside
Took door card of from inside car all cables are fine but still
Would not open by pulling on rod from door handle
Read a post about spraying contact spray on electric connector for actuator
then opening and closing locks by the button on drivers door
Continuously then actuator
Kicked in and door opened replaced with another
Hope this helps anyone
