Hi, Anyone know the major differences between the EG6 and EK4 apart from the year of the car, body etc. Been told they have the same engine (I think) but thats about it.
Andy
The EG is lighter too
This spec is based on the American SI (aka VTI)
Model: SI
Engine;
Engine Code:-------
"In Japan and Europe, as well as a few other exports locations, the VTi was offered in 2 motors: the B16a2/3 (160 hp DOHC VTEC) and the D15B. (130 hp VTEC SOHC) The D15B shares the same head as the US Civic SI (D16Z6) but a unique block, crank, and rods. the car shared the 1.5L displacement of the other D15 blocks, but the rods were the same length as the D16's". Source wikipedia.
Valvetrain: SOHC, 4 vavles per cyclinder, VTEC variable valve timming
Displacement: 1590 cc
Bore & Stroke: 75.0 mm x 89.9 mm
Compression ratio: 9.2:1
HorsePower: 125 hp @ 6600
Torque: 106 lb-ft @ 5200
Divertrain;
Layout: Transverse Front Engine, Front-Wheel Drive
Transmission: Manual Five Speed w/ Starter Interlock
Gear Ratios:
1: 3.250:1
2: 1.900:1
3: 1.250:1
4: 0.909:1
5: 0.702:1
Final Drive: 3.250:1
Differential: Open
Exterior Dimensions;
Curb Weight: 2390 lbs
Weight Disturbution F/R: 62/38
Overall Length: 160.2 inches
WheelBase: 101.3 inches
Overall Width: 66.9 inches
Track F/R: 58.1/57.7 inches
Height: 50.7 inches
Suspension;
Front: Indepentent double wishbone w/ coil springs & 21mm anti-roll bar
Rear: Indepentent double wishbone w/ trailing arms & coil springs
Brakes;
Front: Ventilated dics, 10.38-inch, power assist
Rear: 9.43-inch solid discs
Wheels And Tires;
Wheels: 14 x 5 steel, wheel covers
Tires: 184/60-R14
Hope this helps mate
