1 - 15 of 15 Posts
Hi chaps, got the offer of an L reg civic for cheap cos the timing belt has snapped. does anyone know if this is a safe engine or not?
because its a ohc (over head cam) the chances are its wrecked but hondas are better than most it may sill run
my old mk3 escort cvh ran after the belt snapped.
are you prepared to rebuild it?
when the timing belt snaps you risk forcing a valve into the top of the piston. i wouldnt buy one personally. could be a big job
Discussion Starter · #4 ·
rebuild is not a problem, i can do that myself, but it needs other stuff as well. if it was a case of just a timing belt then it would be just about viable i think, its a bit borderline tho.
Discussion Starter · #6 ·
I'd need to buy it first tho, its on ebay for £200, seems a bit risky to get my money back if i buy it, fix it and sell it on.
Discussion Starter · #9 ·
sounding more like a bad idea all the time! thanks chaps, I'll need to find another project to do!
Tbh mate they arn't the best engines to start with, if you want to build a D series you should build either a D16a9 (out of a 1.6 16v CRX) or a D16z6 (Out of a ESI Civic/CRX)
what i mean paul is that hondas are great and alough a snapped belt is termnial there is a chance with a honda that it may still run as they are ultra reliable
i apoligise for my bad grammer again
thanks for clearing that up. any chance of your input in my head rest question ? i know it dont seem like it but your view is appricated
1 - 15 of 15 Posts
