If like us all with ep3 you have a uneven tyre wear problem get you car four wheel lase aligned
http://www.alignment-services.co.uk/abo ... gnment.asp" onclick="window.open(this.href);return false;
this is where i went big improvement yet the local tyre company tracking said it was spot on, this is because there gages say it right but they only check the toe of the front wheels not all four
What are the "symptoms" of a car that's out of alignment?
A. Have your car checked if you notice:
• Excessive or uneven tyre wear.
• Steering wheel pulls to the left or right.
• Feeling of looseness or wandering.
• Steering wheel vibration or shimmy.
• Steering wheel is not centered when car is moving straight ahead.
This is a very common problem and £50 will sort it out and to be honest you will save that in tyre's never mind the better drive
so i should get mine checked? or is there no adjustment needed?
i get a slight vibration but i believe that a wheel weight has come off from the front.
i think i'm going to have to get it checked!
