About 40bhp mate, there's lots of differences between the a2 and a3, more than between the a and a2 iirc
Intake manifold, cams, valves, ecu, exhaust, pretty much the whole lot
u cant mod the type s to be a type r unless u actually change engines! same with the b16a2 and b16b (the b uses the same stroke as the a2 but uses the b18 block for strength. all 3 engines use the same piston diameter, just the stroke is longer on the b18)
Discussion Starter · #5 ·
Ok one more thing so if a buy a dc sports manifold fitment for a k20a3 will it fit my jdm ep3?
Thanks! sye
