hi could somebody help me out.The biting point on my clutch on my civic coupe vti is right at the top of the ped and im just wondering if my clutch is on its way out.It dos'nt slip but i was overtaking and when i droped a gear it seemed to take a wee while for it to engage like when your driving and you put your foot on the ped and the revs go up.I know its a bit of a shit description.Any advice or help would be much appreciated
cheers
i forgot to add the car has done 103000 miles on origional clutch
the hight biting point sounds like your clutch is on its way out mate, if it doesent slip on pull away they usually slip worst in 4th gear accelerating the revs will go up and down until they finallt settle, i dont know if your getting that?. my clutch did same 4th gear thing but i had gearbox oil leaking onto mine.
hope that helps cheers alex
thanks for the advice folks.I got the clutch (exeddy stage 1) and a teg type r flywheel done yesterday.made a big difference.My old clutch plate was right down to the rivits so it was nearly gubbed
