Hi
My 1993 Civic ESi is taking 3-4 attempts to start up in the mornings from cold. :confused:
The car's done 120k miles with only the ignition module being replaced a few years ago - that was the only problem I've ever had.
The battery's fine (cranks well) and the fuel pressure sounds like it's priming OK too. Fuel is aplenty and runs on V-Power. When you turn the engine over, it kind of splutters and eventually catches on the 3rd or 4th attempt. Once it's started it's fine - no running or idle problems - it only seems to do it first thing in the morning / when cold. I figured if it was the ignition module again - it wouldn't start at all?
I was thinking of getting the plugs and leads replaced. Anyone have any other useful suggestions or familiar with this problem??? :question:
Cheers.
SW.
Cheers for that. You wouldn't happen to know the engine code for a 93 ESi would you? Am I right in thinking it's EG5 D16Z6? (It's the shape below):-
I was trying this website for parts: http://www.japparts4less.co.uk - trying to find decent Honda parts online, but no joy... :cry:
Cheers! :D
yea its a D16Z6 and your chassis will be EJ something but not sure what, will tell you on your VIN plate.
i had a similar problem and it turnt out to be the crank sensor.
