Has anybody changed their fuel pump on a 1996 - 2000 coupe by any chance, I want to up grade mine with a warlbro for bigger injectors.... just had a look at me haynes manual and it says the tank has to come out on a coupe ?
Anyone know for sure or if there is an easy way to do it ?
I know it's in the back underneath the rear the seats in the EG, I'd assume you can access it in the EK as well from the same place...
Just undo the bolt holding the back seat in place and move it out of the way and get all the carpet and stuff out of the way and there should be a little hatch which has been bolted in, the fuel pump is usually under there for changing...
