1 - 19 of 19 Posts
well, ist time to start saving hardcore, ive been quoted for the engine rebuild, this includes dartons sleves baby.
the block will be good for 750bhp, its all down to the kit i put together i suppose.
im aiming in the area of 300bhp low boost 540ish full boost.
the quoted price for the engine build was £5300 including all the parts, arp rods, skunk2 cams, valves, springs, eagle rods, wiseco pistons etc etc.
this a good price?
Nuno
£5300 for the parts and fitting? Does this include the block?
Darton sleeves are about £500, more now with the current exchange rates, and you're probably looking at another £500+ for fitting on those. Who is fitting them, as sleeves is really someone specialist, and I highly suggest you have somewhere who use a CNC machine to cut the block.
Do you mean ARP rod bolts? I would look into getting ARP head studs and main studs too.
Good for 750bhp? I hope you're looking into forged cranks. Do you know exactly the list of parts you'll be getting? For 5300 is that the engine installed too? It seems a little bit steep but then I don't know the full spec...
i couldnt tell you the full spec of top my head, would have to read throuh emails.
and ye i ment ARP rod bolts and yes also arp head studs and main studs too.
yep the block will be CNC'D
yep speciallist darton sleeve fitter
cranks will indeed be forged
and yep tats engine in place.
how much would u pay for the lot?
all built and installed that doesnt sound a bad price to me. The parts will be well over 2k and building an engine like that is specialist work, every thing has to be perfect.
Anyway by the by of cost if your happy with the guys building it and work they have done in the past then price isnt always the thing you should go on.
Does the price include mapping though? If yes then the price is even better
Nope just a base map so i can drive the car normally until i get it proper mapped.
Alan-VTIS said:
your going to drive a 5.5k engine unmapped?
>.> well how am i suppose to get it tunning? it will have a base map, so will run smoothly. i need to drive it for roughly 2/3miles to the tunning company.
lol fair point dude,
Sorry i thought you meant drive it till you save up to have it done. All sounds good though im nearly all saved up to have a bolt on kit done for my VTIS should be done by march i would say
Discussion Starter #9
cant wait to see tat on the road!
u runing low boost? or having a rebuild?
What place is doing the work? Sounds like an alright price, if that includes a blueprinted build and balancing.
What crankshaft are you having?
Don't drive it on a basemap, literally use that to get to a tuning garage. Get them to make you a low boost map to run the engine in for 500+ miles and then go back for full tuning.
What turbo set up are you planning?
_nuno_civic_ said:
[quote="Alan-VTIS":rxwcyydk]lol fair point dude,
u runing low boost? or having a rebuild?[/quote:rxwcyydk]
Just low boost for now mate whatever it takes to make about 270hp so probs 7-8psi. Seems to be about all the stock engine can take anyway, when i did the prelude they suffered from piston ringlands cracking with to high cylinder pressures so im hoping not to have simaler problems with the civic. Think the b18 is a bit tougher for boosting
Seems like we are going to have a few boosted people on here soonish then :mrgreen:
I'm going to be running low power compared to all you lot! Mind you my car is about half the weight of a lot of yours :p
What company has quoted these prices?
I didnt know Darton had any approved installers in the UK. Build sounds nice and depending on turbo/manifold choice and other ancills those power levels will be easily achieved. You could however get well over 400bhp from a simple piston/rod combo for a fraction of the cost, if this is a road car then it may be worth considering.
Good luck mate!!
Discussion Starter #16
Edd said:
Your pockets must be fairly deep as well!
hehe, living at home with parents baby!
as for sleeving their website says they are the only UK fitters of darton sleeves.
inlinemotors in wolverhampton.
Nuno.
1 - 19 of 19 Posts
