IM AFTER ADVISE ON WHAT IS EXACTLY NEEDED IN COVERTING MY 95 CIVIC 1.5 VEI WITH A B16A1/2 ENGINE/GEARBOX??
IS IT REQUIRED TO CHANGE HUBS, MODIFY ENGINE MOUNTS ON CAR, REPLACE COMPLETE LOOM, ECU? AS THIS CAR HAS VTEC ORIGINALLY?
WOULD APPRECIATE ANY HELP.
REGARDS
TARIQ
You will need engine, gearbox, driveshafts, engine mounts, gearshift linkage, wiring loom and ECU. The engine will fit straight in no modification required. About the hubs you should be fine but if you plan to modify the engine you should change them with VTI ones.
Forgot to mention that I am talking about B16A2. With A1 the things are little bit harder cause it has cable operating clutch and your car has hydraulic one. So better go for b16A2
