right fitted a a standard backbox but it dont look the same
(different kink were it mets the center section and exit is straight rather than bent down a bit then straight . aswell as the mufflerbox bit is a bit is longer)
now the center section hits the floor/tunnel on corners
i broke a bolt that holds the two pipes together and moded a new one till a replacement arrives
could it be that (not hanging right)
or could i have a wrong part ? this happened to a mate who had a similair civic it took 3 atemps to get the right one
just want to know if this has happened to anyone else?
i got honda b pipe and backbox thru honda, (EXPENSIVE :()the one that was on there knocked against the rear suspension and heated up the petrol tank as well as hanging low. was a lot quieter and better sounding. also the curves in the pipe were so much better!
this cost 38 squids so i guess i got what i paid for
wen i get the proper bolt im goin back to the motor factors (who will reman nameless cos usally cant fault them) and going to look through there book and double check the part
we all make misstakes we are all human
